COMPREHENSIVE USB2-AB-50PROAP 50 FT. PRO AV - IT ACTIVE PLENUM USB A MALE TO B MALE CABLE 50FT - CENTER POSITION
Comprehensive USB2-AB-50PROAP 50 ft. Black Pro AV / IT Active Plenum USB A Male to B Male Cable 50ft (Center Position) Type: USB Connector Type: USB A to USB B Type: Others Connector Number: 2 Connector Detail: Connector Type 1: USB A male Connector Type 2: USB B male Terminal Gender: Male to Male Specifications: Performance Grade: Better Bandwidth: Supports 480 Mbps High Speed, 12 Mbps Full Speed and 1.5 Mbps Slow Speed Gauge: 24 / 22AWG Jacket: Plenum CL2P rating, matte black finish Cable OD: 6.00 mm, 0.236" UL Rated RoHS Compliant Temperature Rating: 75° C Voltage: 30V Weight Lbs: 1.25 lbs. Shielding: 80% Tinned copper braid and 100% aluminum / mylar wrap
Price: 87.99
